vss wires on pigtail?!?
Car: 1986 IROC-Z
Engine: Vortec 350 with mild cam
Transmission: 700r4 Mild build
Axle/Gears: Stock
Hello,
I have a 1992 t-5 and cannot figure out which side of the pigtail is output and which is ground. It would be easy if my car had a stock wiring harness, but its not. the pigtail is not original, so there is no purple and yellow wire. I need to find out which wire is facing the rear, and which is in the front, assuming that the clip for the pigtail (holds pigtail to sensor) is on the top. I cant find this info anywhere, so Im reaching out to you guys. Please help me if you can. Thank you very much!
Andy
Andy
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
