Wiring problem??? Diming dash lights throw off guages
Old Jul 10, 2005 | 11:53 PM
qytum's Avatar
Car: 92 Formula
Engine: 5.0L TBI
Axle/Gears: 3.73 posi
I am a little confused about this 90 bird. The lights are throwing off the guages. When I put on the headlights with the interior light dimmer all the way down, the guages are reading fine. But as soon as I slide the dimmer to max, my voltage guage drops down 3 volts, oil pressure drops 20psi, and the temp guage also moves a bit. If i put the switch back to low, then everything returns back to normal instantly. The switch is dimming all the lights fine but it just messes with the guages. Anyone have any ideas?
Old Jul 11, 2005 | 12:46 AM
qytum's Avatar
Car: 92 Formula
Engine: 5.0L TBI
ok problem is worst. now when set to max, all the guages shoot to their max except tach and speedo and the interior lights no longer come on. But when i turn it one more notch where it turns the dome light on, i get all interior lights + dome lights and the guages are still maxed. Dimmer switch maybe?
Fuses all good
I have also noticed that i no longer have sidemarker lights. Headlights, taillights, brakelights, and front parking lights all work though.
Also, i tried to jump the wires from the remote dimmer switch and i still have the exact same problem. The interior lights will only come on when the dash dimmer is set to the dome light mode.
Old Jul 11, 2005 | 08:57 PM
qytum's Avatar
Car: 92 Formula
Engine: 5.0L TBI
i pulled the guage cluster out and took a look at the board and everything looks good. Couldn't find anything burnt or shorted. I also ordered a dimmer switch that should be in tomorrow to try. Anyway, anyone have a wiring diagram for the marker lights?
Ghettobird52
Jul 5, 2024 11:18 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
apie2546
Aug 8, 2015 07:12 AM
