Swap 89-92
Old Jul 11, 2005 | 07:37 PM
Tonyrodz's Avatar
Transmission: auto
Swap 89-92
I'm stripping my T/A that has an 89 350 tpi motor and complete harness in it--putting it in my 92 T/A--same setup--89 350 tpi--the 89 only has 2 wires going to the fuel pump through the floor and the 92 has 3 wires going through the floor. Does the 92 have an extra ground? Will my 89 setup work using the 92 fuel pump?
I need help please!
How can I make it work? The 92 is completely gutted and I'm using everything from my 89 setup.
Old Jul 15, 2005 | 09:16 PM
Tonyrodz's Avatar
Transmission: auto
anyone? Trickster?
Old Jul 15, 2005 | 09:51 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Actually there are three wires for your fuel pump in the 89 t/a. There is the pink wire going to the fuel gage, the tan/white wire going to the MAF sensor, ECM, & other locations; then there is the black ground wire located under the right hand rear seat.
Old Jul 16, 2005 | 11:28 AM
Tonyrodz's Avatar
Transmission: auto
ok--so on the 92 the black wire would be the ground wire? So I'd be able to ground it anywhere?
Old Jul 16, 2005 | 11:31 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
that is correct my friend.
Old Jul 16, 2005 | 11:33 AM
Tonyrodz's Avatar
Transmission: auto
You rule Trickster!!!
I might be posting alot more questions for this swap!
Thanks for the help!!
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
aaron7
Exterior Parts Wanted
Aug 18, 2015 05:47 PM
