Lighting problem
Car: '82 & '84 Trans-Am
Engine: LG4 305 & L69 305 H.O.
Transmission: TH200C & 700 R4
Axle/Gears: 3:23 & 3:73 10 bolt
Lighting problem
I own a '84 Trans-Am and my park lights work fine until I turn on the signals, they then go haywire, like something is crossed. I noticed that my park/headlight switch is acting up, the headlights will not raise unless the switch is kind of rocked halfway, could this be causing the wires/lights to cross?
Switch
I agree with Vader, I had a similar problem where my lights were going nuts in the gauge cluster when driving at night. I noticed that when I played around with the switch itself it made a difference.
Replaced the switch and all was fine
Headlight Woes
Thanks dudes, you just confirmed my very thoughts on that switch being worn, can one still be ordered through GM? F- bodies rule!!!!!!!
