10A Gauges fuse blows when i turn the key
Old Jul 23, 2005 | 07:39 PM
Black Beauty's Avatar
Car: 90 Camaro RS
Engine: 305 TBI
my 90 camaro vin e hasnt run in about a year because the lock cylinder was broken and i let it sit but this thing is all mickey mouse now. it was broken into so who knows if the alarm works, it doesnt respond to the clicker, but it responds to the key in the new lock cylinder...i think im just going to rip the alarm out, even tho it cost me. i just want this thing to start.
i also bypassed vats and had no trouble with that so long as it was set right...and ive checked it over and over. well when i turn the key to on the gauges all respond, but if i try to crank it the 10A gauges fuse blows and the car also happens to not start. im getting power to the yellow wire coming out of the ignition switch. does anyone think i can run the yellow wire to the purple wire to start the car, or will the injectors not fire....when i turn the key i can hear the fuel pump prime...
anyone have a problem blowing the 10A gauges fuse when they turn the key?
Old Jul 24, 2005 | 01:55 AM
92rsbowtie's Avatar
Car: 92 rs camaro
Engine: 305 lo3
Transmission: WC t-5
most likely, if that 10A fuse controls your vats, your problem is bypassing the vats. the vats would be a load or resister. when you bypass it, your removing that resistance, which in turns causes your current (amperage) to rise. basically your overloading the circuit and blowning the fuse. never bypass a load, or you will start blowing fuses. other than that, i can't help you with your problems.
Old Jul 24, 2005 | 03:05 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Most likely the circuit that the 10A fuse is protecting has a direct short to ground.
Bypassing the VATS doesn't delete any resistance, the VATS resistors are hard wired together permanently.
Old Jul 24, 2005 | 10:58 AM
92rsbowtie's Avatar
Car: 92 rs camaro
Engine: 305 lo3
current takes the path of least resistance, so how could by-passing it not remove resistance?
Old Jul 24, 2005 | 02:38 PM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
Removing the resistance in this case doesn't means taking out the resistor pellet from the key, or ignition switch, only "bypassing" it with another of equal resistance.
VATS bypass can be accomplished by more than one method, bypassing the key, or ignition swtch resistance is the easiest.
Ghettobird52
Jul 5, 2024 11:18 PM
Jae992
Aug 27, 2015 09:07 AM
TheExaminer
Aug 19, 2015 10:07 PM
Bryan F
Aug 18, 2015 02:28 PM
tnrednneck
Aug 13, 2015 08:57 AM
