speedo fix???
Old Jul 25, 2005 | 12:05 PM
dan_o_89_rs's Avatar
Car: 89 camaro rs
Engine: 305 tbi
speedo fix???
im not sure this is where this should go. please move it if if needed.
i was repairing my trip odometer. but instead of doing it like explained on the forums, i just pulled the needle off, and unscrewed the gauge; instead of pulling out the whole cluster.
my problem is trying to get the speedo needle put on right. when i pulled it off, i was expecting it to be notched so that it only goes on one way. i was wrong.
is there any trick to this? i was following my bro, and it appears to be about 4 mph under reality.
Old Jul 26, 2005 | 12:33 AM
fast83camaro's Avatar
Car: 1983 Camaro "SC-350"
Engine: Mild 350 4-bolt
Transmission: 700R4 w/ TCI Stall
I guess the only way to get it right would be to drive down the road while following someone. Have the lens off the cluster and the needle off the speedo. When your sure your going the same speed as your helper (cell phones are helpful lol), stick the needle on the speedo. Then make sure it's right. That's how I would do it anyways....hope this helps!
BTW, Make sure the car you are following is stock with factory-size tires!
Matt
Old Jul 26, 2005 | 10:39 AM
Car: 89 camaro rs
Engine: 305 tbi
thanks. i guess i really goofed. wish my cruise control worked. (thats something else i've been meaning to fix) then i could set it anywhere, and have someone clock me. and voila. theres construction in town and they have the big signs that display radar readings. i could set my cruise and it would tell me exactly...
Old Jul 26, 2005 | 07:10 PM
dwillis's Avatar
Car: 1991 Trans Am Convertible
Axle/Gears: 3:08
i dont know on your car but there should be a diagram to go by...when you turn your key to the on position your speedo guage should go to a certain position...if you know someone with your model get them to do this and set your needle to that position...ask if someone on here could do that for you.then check with someone going the same speed to assure its correct...
Old Jul 26, 2005 | 08:18 PM
Car: 89 camaro rs
Engine: 305 tbi
hmm thats interesting. ill check my haynes. but anyone witha 89 lo3 700r4... whats ur needle do when u turn the key on? thanks.
Old Jul 26, 2005 | 10:30 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Forget the haynes, it won't help. I had mine off recently and just lined the needle back up with the last mark it was on when I took it off. It happened to be the first mark on the speedo. No tickets yet (fingers crossed)!!!!!!!!!
Old Jul 26, 2005 | 11:17 PM
Car: 89 camaro rs
Engine: 305 tbi
haha found that out real quick. i think i can get it pretty close. thanks fellas.
GTAman
Jul 3, 2024 07:29 PM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
92firebirdguy
Sep 1, 2016 07:53 AM
BWilcox
Sep 20, 2015 12:19 PM
TrevinE
Sep 14, 2015 03:20 PM
