wires everywhere
Old Jul 30, 2005 | 05:17 PM
z28maro's Avatar
Car: 1983 z28 camaro
Engine: 305 - LU5 bottom end.
Axle/Gears: 2.93 stock :-(
wires everywhere
i have an 83 z28 that i ripped out the fuel injectors and went to a carb system. also i took out the a/c heat and cruise control and i'm now left with a mess of wires.
im sure someone out there has done something similar and i was wondering what they did with all them.
personally i cant seem to find the time or interest to rip apart my wiring harness and pull them out one by one.
Old Aug 3, 2005 | 04:29 AM
BRobinson's Avatar
Car: 82 Camaro
Transmission: TH-350
Axle/Gears: 3.08
Look Here
Pretty much, the last paragraph says it all
Old Aug 3, 2005 | 10:12 PM
z28maro's Avatar
i was afraid of that... o well a few more lonely nights in the garage with just myself and a case of beer
Old Aug 4, 2005 | 03:06 AM
BRobinson's Avatar
Car: 82 Camaro
Axle/Gears: 3.08
It's not all THAT bad. Just remove the kick panel and disconnect the harness at the ECM, then unclip the bundle where it goes into the engine compartment. With a little persuasion and threats of setting the car on fire and rolling it off a cliff, they should come out. Just clip the harness with enough wires so that it can be reused in case you come across someone who needs it. No point in destroying yet another perfectly fine original Camaro part.
Old Aug 4, 2005 | 03:13 AM
BRobinson's Avatar
Car: 82 Camaro
Axle/Gears: 3.08
Oh, and for a bonus, I'm gonna throw in the obligatory, "If you already went through all that trouble, you should've just swapped in a 350" post that everyone seems so fond of .
Old Aug 4, 2005 | 10:37 AM
z28maro's Avatar
also one more question. is there an easy way of ditching my computer completely and going completely old school, i know it can be done i just dont know how or would it be easier to take it out and put in an aftermarket one that just does the bare minimum.
Old Aug 4, 2005 | 10:39 AM
z28maro's Avatar
let me rephrase that if i take the ****er out what am i gunna mess up and have to rewire. which rewiring doesnt bother me as much as playing with an outdated mess
Old Aug 4, 2005 | 01:01 PM
BRobinson's Avatar
Car: 82 Camaro
Axle/Gears: 3.08
You'd need aftermarket gauges, *I think* I don't know exactly how your setup is. You wouldn't need to really rewire anything, since the power wire for the fuse block goes off of the starter, and in through the firewall on the driver's side. The wires you'd be messing with are on the pass. side
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Bert87
Aug 23, 2015 03:50 PM
