Relays on firewall
Car: 86 IROC
Relays on firewall
I'm having a maf problem. Low voltage code comes up constantly. Have replaced ecm and maf (microtech, big power gain). I found one relay with a loose terminal (F) after checking entire wiring harness. It is the 3rd one from the fender What relay is this for? Two of these relays look identical, can I interchange? Will an 86vette relay work on my 86 iroc?
Car: 86 IROC
burn off relay
Thanks Trickster. New question. Since my new maf has no wire, only a circuit board, will the burn off process damage the new maf?
