changed cluster now tach is wrong
Old Aug 7, 2005 | 09:08 PM
dwillis's Avatar
Car: 1991 Trans Am Convertible
Axle/Gears: 3:08
my speedo burned out for some reason so i replaced the whole cluster from a 91rs...mines a 92 5-speed 305...the part# on both pieces were the same but my tach is way off...the shift light works right.all i know about the other car is it was an automatic car...what can i do to fix my tach problem....thanks for any and all help
Old Aug 8, 2005 | 08:42 PM
Crall13's Avatar
Car: 92 Formula
Engine: 5.7 L
If your tach is constantly off by the same amount (ex. it states 3k when it's 2k or 5k when it's 4k) than you just need to re-align your needle. To do this just pull the needle off (softly) and put it in the correct place. You can do this while it's off, but you may need to start the car and let it warm up. Then set it to the proper idle speed. Someone else could probably be more helpful with what your idle is for your car.
Old Aug 9, 2005 | 09:01 PM
RebelRacer's Avatar
Car: Bitchin' 92 RS
I have the same problem, this is really helpful, thanks
Old Aug 9, 2005 | 09:09 PM
dwillis's Avatar
Axle/Gears: 3:08
would it matter that my cluster now come from an automatic car...when my shift light comes on when im on it ,it working right(just before engine looses power) but the tach is like on 8k pegged out...
Jeremys87
Jul 14, 2022 09:08 PM
Armored91Camaro
Aug 25, 2015 12:01 PM
355sbcTPI
Aug 19, 2015 04:38 PM
stalkier
Aug 7, 2015 04:49 AM
