Speedo stuck at 140 while driving
Car: 1992 Firebird Formula
Engine: 305 TBI
Transmission: 700 R4
My 1992 firebird 305 Tbi the speedometer does not read right it stays at 140 mph as soon as you start rolling. It does it in frwd & rev . speeddo & speed sensor replaced no luck yet. Is the computer toast or is there another problem ? Has anybody had this problem? looking for answers to this problem.
Engine: 305 TBI
Speedometer stuck at 140 while driving
Car: 91 Camaro RS
Engine: Holley MPFI, AFR 195, Hot Cam=375HP
Are any of the other guages acting funny? I had a bad ground circuit in mine that made it do the same thing. Also do a voltage drop test on the ground between the firewall and the batt. You won't know if the firewall to guage ground is good but you will know if the rest of em are. Voltage shouldn't drop more than .5 volts.
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
Originally posted by Vader
Welcome Aboard!
You may need to look into the VSS buffer circuit.
Welcome Aboard!
robtmyer: if the needle gets stuck, try turning the car upside down and shaking it... lol, just kidding.
theres a VSS buffer box under the dash.. it takes the signal and splits it to 4000 pulses per mile for the speedo and makes a 2000 pulse per mile signal for the cruise control.
most likely, this is the box going bad, and making your speedo go wacko.. id get one used from another car, as they're usually not stripped from salvage yards, and they generally dont go bad unless they get wet..
Engine: 305 TBI
I got a new one from GM but they can't even tell me where it goes at.
If I only knew were it goes I could replace it. Has anybody replaced theres on a 1992 Firebird with a 305 TBI ? TGO Supporter
Car: 1989 Iroc-Z
Engine: 5.7L TPI
If it was the VSS buffer box that you got, it is located under the dash next to the ECM. If it was the VSS sensor that you got, it is located in the side of the transmission case.
Engine: 305 TBI
Its the Buffer I got from GM. Because I asked for a D.R.A.C. Buffer with is a Digital Ration Adapter Controler the guy at GM said he would check into it and he called back and said this is the one for my car. The box says buffer asselmby. Its a little white box. I will look by the ECM agian to check if I can find its location.Junior Member
Car: 1988 IROC
speedometer stuck at 140
Yeah - I have the same problem. Helps if I take my foot off the gas though...
(Sorry man - I just couldn't resist!)
Hope you find the problem - keep us posted!
Jonathan
Jonathan
Engine: 305 TBI
Found out what was wrong the person that owned it before me got a 700r4 out of a truck and they have magnetic pickup and a reluctor gear as mine does. So this setup has a higher pulse rate that makes it not compatable with the ECM in my firebird. So I have to go take off the tail shaft housing and put the drive gear on the shaft. Then put correct speed sensor in and its driven gear. That will make it good to go.
IROCZDAVE (88-L98)
Aug 24, 2015 06:54 AM
beachrodder
Aug 7, 2015 04:27 PM
