factory tach and gauges
Old Aug 13, 2005 | 10:18 PM
oldschool's Avatar
Car: 1985 Pontiac Firebird
Engine: 2.8 LB8 HO
Transmission: 700R4 with OD
Axle/Gears: 10 bolt 7.625 open-factory 3.42
In swapping out the idiot lights for the factory gauge cluster on a 1985 Firebird will the alternator continue to charge tha battery after the change over to gauges, or will the "battery" light circuit need to be maintained to accomplish this? I have the GM shop manual, and the charging circuit diagram is different for the warning light and gauge cluster cars. Thanks.
Old Aug 15, 2005 | 09:47 PM
net_coma's Avatar
The volt meter should tell you if it is charging. Also, from a change on my 84 monte carlo...the wire ways in the dash will make correct contact to the the pads in your new assembly. Just dont button everything up until you take a min to be sure all is working.
Bubbajones_ya
Jul 6, 2024 08:32 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
TrevinE
Sep 14, 2015 03:20 PM
86IROC112
Sep 11, 2015 04:04 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
