fuel pump power and negative wires
Old Aug 21, 2005 | 01:10 AM
Duke901's Avatar
Car: 89 Formula
I took the harness out of the car, ( im going carb ) so i have no fuel pump relay or any computer wires left. But i want to run the stock intank pump. What wires would i use to get power and ground for the pump to work.
Thanks Mike
Old Aug 21, 2005 | 09:32 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
There is a tan/white wire that you can wire up to the ignition switch for power when you start the car. The pink wire is for the gage and the black wire is for the ground.
Old Aug 21, 2005 | 10:10 AM
Duke901's Avatar
Car: 89 Formula
technically the pump should already be ground, so I just have to splice into the tan/white wire and hook it to a toggle switch or the ignition switch and it should run.
Old Aug 21, 2005 | 10:21 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Technically you are correct the pump should already be grounded through the black wire in the harness. However since you asked about it in your post I mentioned it. Now if you want your gage to register the fuel in your tank you will also need the pink wire.
Old Aug 21, 2005 | 10:27 AM
Duke901's Avatar
Car: 89 Formula
the pink wire should still be hooked up. I only took the computer and the wires out from under the hood. So the black wire thats on the tank for ground should still be hooked up and so should the tan/white.
So i just have to cut and splice power into the tan/white and everything should be ok lol
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
Jae992
Aug 27, 2015 09:07 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
