Power Window Humidity Problem
Old Aug 21, 2005 | 04:19 PM
crrllmich's Avatar
Car: 91 Camaro RS, 99 Camaro Z28
Engine: L03, LS1
Transmission: 700R4, T56
Axle/Gears: bunch of 10 bolts how scary is that
Ok well I have already replace the motors so don't suggest it...and what fun THAT WAS!.. ok well heres the problem:
Lately around here as some of you know its been hot as sh*t and the humidity is at outragous levels. Well when its gets to be this hot the windows will do the common lag problem... they will slow and stop somewhere and then after I wait a while they will continue up.
I did a search on this but thanks to the 8 million people who placed the same question about dieing power window motors I can not find the answer.
Another thing is it sounds like the motors are just struggleing to get the windows up and it just sounds horrid.
Is this a simple fix with new switches? Lack of power? or something else?
When it is cooler out they do go up fine but they still seem to sound like its trying to hard.
I do not want to replace the motors again so whats your ideas?
Old Aug 21, 2005 | 09:49 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Is this with the doors closed or does it do the same thing regardless of whether they're open or closed? If it only does this with the doors closed you might have something binding.
Old Aug 21, 2005 | 10:58 PM
crrllmich's Avatar
Engine: L03, LS1
Open or shut it does it. Nothings preventing it from going up I checked for that. Its just seems the motors are just not getting enough power.
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
neekolzun
Aug 24, 2015 04:59 PM
stalkier
Aug 13, 2015 12:59 PM
