Headlight Motor Removal
Old Aug 22, 2005 | 06:19 PM
shipfitter_sjd's Avatar
Car: 1992 Camaro RS Convertible & 1983 P
Engine: 305 TBI & 305 4 BBL & 4.7 liter
Transmission: Auto & Auto & 5 Speed Manual
My daughter's '87 Firebird has a case of lazy eye. One headlight pops right up and the other does not. With that being said.......
I bought a headlight motor repair kit from TDS.
How hard is it to pull out a headlight motor? Any helpful hints, insights or techniques?
Thanks!
Steve
Old Aug 23, 2005 | 03:01 PM
little P's Avatar
Car: 89 Formula
Engine: 350ci, tbi
Yeah definitely buy one of those box end wrenches with the ratchet on the enclosed end. I'm pretty sure it was a 10mm.
Take out the headlight,
Take off the outer shroud thing. Need torx bit for that.
Remove the three screws holding the motor in place. Then the nut holding the control arm mechanism and wallah.
I had problems with my motors so i ended up when it was all said and done removing and replacing them about 5 times each side.lol. I think in the end i could full dissassemble one in like 5 minutes.
Old Aug 23, 2005 | 07:02 PM
Thanks....
The headlight repair kit from TDS had the instructions in it, and it was pretty much straight forward, just like you said.
Mechanically it works, but apparently the motor is toast as well, because it does NOT work. I cannot recall seeing it work, ever.
Always something.
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
mhatfield 14
Aug 15, 2015 10:47 AM
stalkier
Aug 13, 2015 12:59 PM
3rdgenparts
Aug 8, 2015 07:09 PM
