HELP...fuse keeps blowing...don't know where to start
Old Sep 6, 2005 | 08:09 PM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
One of my fuses keeps blowing in the fuse box. Its the fuse for the power mirors, power door locks, hatch pull down switch on the center counsel, horn, interior lights, and radio. It all seemed to start doing this when i pulled out my tach to fix the oil presure gauge. I would turn on the radio and a 20 minutes later it would blow. I put the radio on a separate fuse thinking that the radio was causing it and this solved the problem for awhile. But now its back. Now i have the gauge working but the fuse keeps blowing. What gives? Its not blowing imediatly..it takes awhile (id say a few days cause i dont drive it regularly) so for the past month or so ive been throwing new 20 amp fuses at it. But now its bugging me seeing as how this is really the one thing wrong with the car right now.
Old Sep 6, 2005 | 09:17 PM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: 2.73 Posi w/Disc
Try pulling the cig lighter and see if it goes away -- that was my problem. Could be a lot of other things, though. If you have a meter capable of measuring 20+ amps, you can pull the fuse and insert the meter in its place to see how much power the circuit's drawing with key on/off, etc...
Old Sep 6, 2005 | 09:35 PM
subroc's Avatar
Engine: 355 TPI
Oh ok thanks i'll try that next time i get a chance..(im up at the university of connecticut and the car is at home). If that is the problem what should i do to fix it? I do seem to remember that my cigarette lighter doesn't work and it just stopped recently ( i got friends that smoke). Should i pull the cigarette lighter out of the dash and see if there is a loose connection or something? Or should i stop being dumb seeing as how i don't smoke and just throw the damn lighter away? lol
Old Sep 6, 2005 | 09:51 PM
burnout88's Avatar
Car: 88 IROC
Axle/Gears: 10 bolt 3.73
Disconnect the plug at the back of the lighter, more then likely it is the lighter.
Old Sep 6, 2005 | 10:01 PM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
On mine, I only had a problem if the heater element was in the socket. I eventually went to Wal-Mart and bought an entire socket/heater element for around $5 -- problem solved.
Old Sep 8, 2005 | 10:43 PM
LASGTA88's Avatar
Car: 1988 GTA 1988 Z28 1983 Silverado 4X4
Engine: ZZ4 opt 4 in GTA, drag car Z28, and 350 4X4
Transmission: 700r4 for now GTA, none Z28, TH350 4X4
my buddy had a penny in his lighter and it kept doin that.. they are right it is most likely something with the cig lighter.. i took mine out completely and just dont use one
LA
Old Sep 8, 2005 | 11:49 PM
subroc's Avatar
Engine: 355 TPI
I didn't realize that it could be such an easy solution. Thanks everyone. I'll keep everyone informed if it helped or not. It may be awhile before i can test it and get back to you seeing as how im up at UCONN and my camaro is 59 miles away in my hometown nice and snug in my moms garage bay (i kicked her car out )
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
