LED Bulbs???
Old Sep 10, 2005 | 11:27 PM
jimp2001's Avatar
Car: Red on Red 89 RS
Engine: LO3 305 TBI
Transmission: TH-700R4
Axle/Gears: 10-bolt / 2.73
LED Bulbs???
It's the latest thing now to have LED bulbs, because they are brighter, and they never burn out.
I got a few bulbs for my car... for my city lights (can be seen in sig), side markers, and blinker/parking lamps.
The 194 bulbs for the city lights and side markers are great, but I had a problem with the blinker/parking lamp LED bulbs I purchased.
When the LED bulbs are installed, and I turn on my parking lights, the blinker indicator in the dash is lit dim. When I turn the blinker on, the flasher wont flash the blinkers because they do not draw enough current.
I was wondering if anyone has tried to use these bulbs and got them to work by adding a resistor to the line, replacing the stock flasher, or if there is a bulb that is a direct plug in that will draw enough current to make my flasher flash the blinkers.
Thanks for any help in advance,
-Jim
Old Sep 11, 2005 | 04:20 AM
84 Z-28 350's Avatar
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
autozone sold a replacement flasher for trailers(at least they did a year ago....before I got shipped to korea...)It's solid state, it dosen't have a bi-meatle strip, like a normal one, and should solve your problem.
Old Sep 23, 2005 | 02:14 PM
axeman's Avatar
Car: 84 HO Z/28 & 91 Z/28 Vert
Engine: 84 - 305 CARB 91 - 305 TPI
Transmission: 84 - 700r4
I believe they are called ...no load flashers
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
RedLeader289
May 28, 2019 01:47 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
