checking maf
Old Sep 17, 2005 | 08:06 PM
TABBOO's Avatar
Top Answer: 1
Car: 87 T/A
checking maf
Does anybody know how to check a bosch maf from an 87 TA.
It is a 305 TPI. I keep getting codes 22 & 33 together. I think maybe my maf might be bad.
Old Sep 17, 2005 | 08:24 PM
Vader's Avatar
Read the output voltage with a meter:
Back-probe the MAF connector, start the engine, and read the voltage.
Old Sep 18, 2005 | 10:04 AM
Vader's Avatar
Incidentally, I provided instruction how to check the MAF, since that is what you asked.
Your root problem, however, is likely going to be found to be the TPS setting that is too low, not the MAF. You can use that same meter to set the TPS properly.
Still, it never hurts to know how to test a MAF with only a meter.
Old Sep 18, 2005 | 09:22 PM
TABBOO's Avatar
Top Answer: 1
Car: 87 T/A
Thanks for the info. I could use an opinion about the tps thing. After it sets a code if it sits until cold, I clear the codes, everthing is fine, I drive like 10 miles to a car show. When I get back in to go home the code sets, first just a 22 then if I drive with the 22 next a 33 & the car sputters & has no power (limp home mode I presume). If I check tps operation with a volt meter it shows OK but still the problem persists.
If the base idle is off would this be the problem?
This problem is very frustrating. I would just like to be able to drive my car again.
Old Oct 3, 2005 | 08:42 AM
TABBOO's Avatar
Top Answer: 1
Car: 87 T/A
Thanks for the help. It turned out to be a couple bad pins in the ECM connector & a frayed TPS wire. I had to pay the man $275.00 to diagnose it, but the car runs fine now so it was worth it. Thanks again!!!
Old Oct 4, 2005 | 07:39 PM
Vader's Avatar
Back to a low voltage signal from the TPS. That's usually the cause.
specialized
Jun 18, 2022 09:26 AM
chazman
Aug 28, 2018 03:25 PM
GTAman
Sep 21, 2015 09:57 AM
Bert87
Aug 23, 2015 03:50 PM
chazman
Aug 22, 2015 02:01 PM
