Trouble with TPS circuit.
Old Sep 18, 2005 | 08:22 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
I have started to have a lot of trouble with the throttle position sensor's circuit. I say circuit because I am totally stumped on what it could be. Here is the problem: I drive or sit in park while monitoring everything with tunerPro. I get very false readings from the TPS. I will have the gas pedal/throttle totally not moving and recieve a reading that will fluctuate all over the scale. I have had it sitting at idle and give a voltage reading of .55 to .00 to 2.3 to 4.3 back to 1.5. And that is all in the course of 1-2 seconds.
I have set the minimum voltage reading many times. I have replaced the old sensor with a new sensor. Both read good with a DMM though. I have followed the wires all the way back to the ecm and found nothing bad. I have tried it on 3 different 730 ecms. I recieve no ses codes. Please do not post the 'How to set min. TPS voltage" article. Where should I go from here?
Just went out and double checked all of the voltages with a DMM. I do get a 5 Volt reference signal, I get the correct voltage at WOT and closed throttle. I get the correct voltage from the black lead to the positive battery terminal. also the correct voltage across the black to blue lead.
Old Sep 18, 2005 | 08:48 PM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: 2.73 Posi w/Disc
As a quick test, run an auxiliary ground from the TPS back to the ECM ground. I had a similar problem once. It was a bad TPS & a bad ground simultaneously.
Old Sep 18, 2005 | 09:05 PM
Tibo's Avatar
Car: 1991 Z28 Vert
I am not sure what you mean by auxillary ground from the TPS to the ecm. I checked the voltage at the ground wire it shares with the IAT sensor and it came up good.
Old Sep 18, 2005 | 09:45 PM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
I mean running a wire from the black wire at the TPS back to the ECM. If you're running the 305 TPI ECM, it should be a black wire at connector B6
Old Sep 18, 2005 | 10:53 PM
Tibo's Avatar
Car: 1991 Z28 Vert
For the most part the problem seems to have started overnight too.
mrbird
Oct 20, 2015 03:43 AM
HoosierinWA
Oct 7, 2015 10:15 AM
racereese
Oct 3, 2015 03:46 PM
Lmancha96
Sep 25, 2015 08:11 PM
BWilcox
Sep 20, 2015 12:19 PM
