Wiring an Air/Fuel Raio gauge
Car: 91 B4C, 17 C7 GS, 16 Denali DMax
Engine: LS3, LS3, LML
Axle/Gears: 3.23, 3.42, 3.23
I have an Autometer air/fuel ratio gauge. I was under the impression this wired directly to the O2 sensor. However the O2 sensor is a 1-wire and the gauge is a 3 wire (1 being ground).
Do I need to get a different O2 sensor? Or splice it in somehow?
Thanks!
Thanks!
Car: 89 Formula Firebird
Engine: 305 - Demon 525
How much was the gauge? If I cheap out I'm going to do this instead of getting a gauge.
https://www.thirdgen.org/newdesign/tech/o2tuning.shtml
Car: 1992 Trans/am convertible
Axle/Gears: 2.73 drum WS6
If its not heated the readings would be off untill, pretty much, the closed loop when the O2 sensor is warmed up.
Ghettobird52
Jul 5, 2024 11:18 PM
