Fan, Oil press., and temp gauge dont work
Old Sep 18, 2005 | 11:47 PM
LASGTA88's Avatar
Car: 1988 GTA 1988 Z28 1983 Silverado 4X4
Engine: ZZ4 opt 4 in GTA, drag car Z28, and 350 4X4
Transmission: 700r4 for now GTA, none Z28, TH350 4X4
i cant get either gauge to come on and the elec fans dont come on at all...
anyone know what this is???
its a 88 GTA with digital dash..
i can put a switch on the fans but i need the gauges
LA
Old Sep 19, 2005 | 06:57 PM
LASGTA88's Avatar
i grounded the relays on the fans and got them to work but still need gauges... NEED HELP!!!!!!!!!!!!!!!!!!!!
PLEASE!!!!!! i have to have it running safely in a day or two..
LA
Old Sep 20, 2005 | 03:29 PM
Difflock's Avatar
Car: VIN=85 T/A, CAR=82/3 T/A gfx, go figure. She's a T/A anyway!
Engine: 5.0, Holley 600 cfm 4-barrel
Transmission: THM350 ??
Have you checked your fuses? I've got an earlier T/A but I would assume that there's a fuse or two for the instrument panel.
Next step, check the oil and temp sender units connections. I THINK you do this by pulling the connection off the sender and then running that connection to earth - the gauge should then go to full deflection. If the gauge does work then suspect a faulty sender unit.
I SAID I THINK THAT'S HOW YOU DO IT, BUT DON'T QUOTE ME...YET!!
Hopefully some electrickery type person can confirm this on your model of 3rdGen - I don't want to be blowing the cars' comnputers up!
Mark.
Old Sep 21, 2005 | 06:42 PM
LASGTA88's Avatar
i understand and thank you lol
the dash works.. its all digital and the fuel and speedo and ALT gauges work fine just not temp or oil.. im gonna try grounding them since almost everything is ground powered.. we will see tomorrow night.. have another concert tonight
LA
Ghettobird52
Jul 5, 2024 11:18 PM
Jeremys87
Jul 14, 2022 09:08 PM
Reddeath210
Oct 6, 2015 08:20 AM
Navy8125
Aug 21, 2015 09:32 AM
ChevyZ71
Aug 13, 2015 07:30 AM
