i'm baffled, wiring behind back seat
Old Sep 24, 2005 | 11:39 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
i have a 1986 camaro with the lg4, it has a mechanical pump on the engine, i'm going to do a tpi swap but the bulk head behind the back seat has 3 wired, a thick pink one, a brown one and black ground, why would i have these if there is no electric fuel pump? although some say a low pressure helper pump could have been installed, why dont i have a fuel pump fuse in the fuse block? help!
Old Sep 24, 2005 | 02:54 PM
PneumaticTire's Avatar
Car: 1986 Camaro Z28
Transmission: Who orders an auto in a Camaro??
Axle/Gears: Economy gears..once again, WHY?!?
There is still a sending unit in the tank. It has a float on it with a varible resistor that is wired to your gas gauge in the dash. Thats how it knows how much fuel is in the tank.
Old Sep 24, 2005 | 04:53 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
yes i know that, but that only requires 1 wire to the fuel level gauge, obviously there is a ground
Old Sep 24, 2005 | 06:51 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
The fuel pump fuse is under the hood bolted to the fender right behind the radiator support.
Old Sep 24, 2005 | 10:02 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
There are three wires there because of the electric fuel pump that is in the tank. Now before someone starts blasting me and saying things like "but its got a mechanical pump at the engine". Let me say this, yes the LG4 and the L69 engines both had mechanical fuel pumps, however the L69 engine also had a electric fuel pump in the tank which was used as a supply pump to provide fuel to the mechanical pump at a rate of 3 PSI. Also in their infinite wisdom, GM incorporated the wiring for the electric fuel pump in all the models off the assembly line. This saved them money by not having to make up a bunch of different wire harness's for each model. If it wasn't used then it was just tucked up out of the way.
Old Sep 25, 2005 | 01:15 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
sweet, thanks trickster!
Old Sep 25, 2005 | 08:30 AM
Vader's Avatar
And that wire would be the tan (brown) one.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
lee01
Apr 9, 2016 01:56 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
