Removed my gauge cluster...re-installed...and now my buzzer will not go off
Old Oct 1, 2005 | 08:24 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
I took out my gauge cluster to add some LED's which went well...but when I re-installed the cluster...my headlight buzzer would not go off until I turn the key off. There is a prong on the back side...and if I touch it with a test light, I can get the buzzer to shut off and work normal. Sounds like some type of gorund to me. So, what I did was run a wire from the prong...and grounded it...and now it works fine. Not really want I wanted to do..but it fixed the problem. Does anyone know what has happened? Thanks BTW, it's the 90-92 electric cluster....
Old Oct 1, 2005 | 09:20 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
I've got the same thing going on but haven't had time to look at it yet. But I completely removed my cluster to install all autometers. So maybe it's got something to do with a break in the circuit from where you put the LED's in? I'm
Old Oct 1, 2005 | 09:37 PM
Engine: 5.7
I've had LED's in mine for about a year now...I just upgraded so they area bit brighter....never had any problems with it until today..
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Eric2ndGen
Nov 5, 2015 01:51 PM
3rdgenparts
Aug 8, 2015 07:09 PM
