Signal Light Fuses
Old Oct 13, 2005 | 12:10 AM
Poisonworm's Avatar
Car: 1985 Pontiac Firebird
Engine: 305 CI V8 LG4
Transmission: 5-Speed
Signal Light Fuses
Hey all
I got a problem. Theres a short somewhere in my car, seemingly the signa llight wiring area. lately (the past week), i keep blowing the fuse for my signal lights. i relace the fuse, it works fine till it pops the next one...I've tried a 20, a 30, even a 40. I just wanna know if anyone can point me in the right direction....any common places on an 85 Bird to get a short, that ONLY affects the signal/parking lights? when the fuse IS holding, all signals work fine. any help greatly appreciated...thanks
Old Oct 16, 2005 | 09:46 AM
Vader's Avatar
Are you able to determine what action causes the fuse failure? For example, using the left turn signal while the parking lights are on, etc?
Old Oct 16, 2005 | 08:07 PM
Poisonworm's Avatar
honestly, the only action that pops the fuse it seems at ALL is hitting a bump...seems like a loose wire thats lost its insulation. One of my neighbors mentioned it may be the relay under/around my fuse box under the dash....is this possible? I've sat and played with the switch for a good 15 minutes, and the fuse never blew.
thanks!
Old Oct 17, 2005 | 08:29 PM
Vader's Avatar
Remember that the turn signal circuits are wired through the steering column to the turn signal/hazard switch, and through the brake switch. There could be wiring (insulation) problems in any of those places.
Old Oct 20, 2005 | 03:36 PM
Poisonworm's Avatar
well...it seems to have stopped for now...but i'm still keeping an eye on it...
I am curious though. I've noticed my driver side "demon" (parking) light seems to intermittently work when i have my headlights on...half the time it won't go on, the other half it will. it also doubles as my signal light obviously, and that DOES work 100% of the time. The rear lights work all the time though....strange...is that possibly where my short could be?
Thanks again!
:::edit::: added a little more descriptive info
Old Oct 25, 2005 | 08:39 PM
Poisonworm's Avatar
And I'm back...blah...
Couple updates, hoping for more info. I checked the bulbs in my signal lights (front AND rear). One had one of the filaments gone. So i replaced it. parking lights still work, but now I'm still popping my fuse. it blows the second i turn the key into the ON position...don't even have to crank the engine now and it blows. I'm using a 30A fuse in the 20A signal/B/u slot. possible issue there? will try a 20 A soon. I realized my backup lights have NEVER worked, so i checked those bulbs when i had the rear light assembly apart. no issues that i could find...
I noticed a bundle of wires sticking out of a black box on the back wall of my trunk though, seems like a relay of some kind. I can't tell for sure, but it looks almost like some corrosion has taken place down there...either that or the electrician tape is falking apart. Any suggestions before i do some SERIOUS damage to either this car, myself, or my pocketbook?
Old Oct 26, 2005 | 06:55 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Sounds like it might be an issue with the back-up light wiring; where they don't appear to work, there could be a shorted wire or something that contacts when hitting bumps.
You'll have to trace those wires from the rear bulkhead out to the taillights.
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
dibella989
Sep 1, 2015 04:12 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Omega
Aug 10, 2015 12:46 PM
