new distributor
Old Oct 17, 2005 | 09:01 PM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Transmission: MN12 6speed
Axle/Gears: 3:42
new distributor
so i got this petronix billet plug and play distributor with mechanical advance limiting adjustment its part #pnx-d100811 but i noticed my old on has the ignition module at the side with some plugs near the firewall is it still possible to installl this? these two wires on the new one are for the coil which i have the msd gm dual connector how can this work out?
Old Oct 17, 2005 | 09:07 PM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
and this is my old one
Old Oct 19, 2005 | 01:01 AM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
thanks for all the help guys lol
Old Oct 20, 2005 | 03:55 PM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: 2.73 Posi w/Disc
If the PCM will run the engine properly without any distributor reference pulses, then I think it will work. If not, then you'll probably have to pull the pulses off the coil primary (I'd guess the same goes for the electronic tach, if you've got it). I'm not certain without checking into it more if there's danger of voltage spikes on the coil primary which could destroy the PCM/tach.
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Jlanz55
Sep 29, 2015 08:55 AM
Damon
Sep 26, 2015 04:29 PM
