manual to auto swap, neutral switch question
Old Oct 30, 2005 | 02:17 AM
CamaroKid89RS's Avatar
Car: 89 Camaro RS/SS
Axle/Gears: 10 bolt with 3.42
First off I am putting an LT1 in my car. The harness I have is a custom one by Ron Francis wiring. For the park/neutral they have a relay that you can either splice into your neutral switch or plug in depending on the shape of the connector. How can I plug this in with my neutral switch that I have? (It's the one for the manual) The switch was where the clutch pedal would have been, so if I plug it in there now, it'll never get switched because there's nothing to switch it. Where can I splice this in to make it work?
Old Oct 30, 2005 | 05:56 AM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
i thought the nuetral switch would be on the shifter...
Old Oct 30, 2005 | 07:35 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
It is on the shifter, he should remove the shifter cover plate and look there.
Old Oct 30, 2005 | 07:52 PM
You guys were right, although i figured this out after I got a good night's sleep. I was up till 2 AM and I wrote this right after all that work. Thanks guys.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
redmaroz
Aug 16, 2015 11:40 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
