blower motor only works on high
Old Oct 30, 2005 | 05:06 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
my blower motor in my car only runs when put to the "high" setting. all the lower settings are like leaving it in "off" any suggestions? i believe there was a relay or resistor in the pathway that would allow for lower blower motor speed settings.
Old Oct 30, 2005 | 05:08 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
There's a resistor mounted inside the blower box.
Old Oct 30, 2005 | 08:21 PM
xpndbl3's Avatar
Car: 1984 Z28
could the switch possibly be defective or should i just try to locate the resistor instead as the source of the problem?
Old Oct 30, 2005 | 09:27 PM
Ian_F's Avatar
Car: 1996 Jeep Cherokee
Engine: 4.0
Transmission: 5 speed
the resistor controls all the lower fan settings, but on high the fan gets full voltage. So that means it doenst go through the resistor. If none of the lower speeds work, 99% of the time its the resistor. The switch obviously works, because you can switch it to high and switch it off.
Old Oct 30, 2005 | 09:39 PM
xpndbl3's Avatar
Car: 1984 Z28
anyone have a part number for the resistor to purchase from GM or aftermarket somewhere?
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Street Lethal
Aug 13, 2015 08:28 PM
