Need help wiring, single fan and electric water pump
Old Nov 3, 2005 | 03:38 PM
NEEDforSPEED's Avatar
as the title says, my fan was rewired to a relay but i cant remember how i did it, the wire got knock off some how so no way i could trace my steps, my electric water pump shows how to do a toggle switch, but thats not how i want it, i want it to turn on as soon as the ignitions on instand of a toggle,
thanks for any help....
Old Nov 3, 2005 | 09:30 PM
anyone?
Old Nov 4, 2005 | 07:49 PM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: 2.73 Posi w/Disc
The fan normally runs through a relay. Was yours modified or is it still going through the factory relay? If you want to turn the fan on with the factory relay, ground the thin GREEN/WHITE wire at the relay. It's not really a good idea to have the fan always running because it doesn't make for good economy or typically even for decent power, but if you wanted it on the entire time, you can just permamently ground out the GREEN/WHITE wire. This would run the fan as long as the key's in RUN.
eightsixseven
Dec 16, 2024 01:50 PM
evilstuie
Jan 9, 2020 08:29 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
Street Lethal
Aug 12, 2015 11:33 AM
