ECM or MAF defect
Old Nov 6, 2005 | 10:53 AM
327 iroc's Avatar
Car: ī86 Camaro IROC-Z/28 T-top
Engine: 327 (331)TPI
Transmission: th700r4
Axle/Gears: should be 3.73
ECM or MAF defect
Hi!
I bought a car with a awaped engine (327). Under the summer i crused along without a single problem untill August. The Check engine soon light comes on and the engine stalls at idle. but if i dissconect the MAF-sensor it runns again but not aswell as before. The ECM has been temperd with a few times and i got alot of trouble codes as folows; 25, 33, 34 and 36.
Pleace help me!
I bought a knew sensor but it still stalls at idel.
tips neded.
Old Nov 7, 2005 | 12:21 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
One thing you might check. There are several grounding connections on the back of the engine, on the cylinder heads. Very hard to get to, but they will work loose or corrode and lose connection, cause these problems. Generally a bad ECM will not throw codes as it doesn't see the external problem. Not always I guess but usually.
Old Nov 7, 2005 | 01:31 PM
327 iroc's Avatar
Okay! thanks for the tip
I will check those when i install the louvers tomorrow
(my English may not be the best but i hope itīs understandible)
Old Nov 9, 2005 | 04:42 PM
327 iroc's Avatar
I have checked the groundings that i had found but they all are free from corotion. But I donīt know how many grounding places there is behind the engine, i found one from the engine that lead to the mounting just to the right of the distributur.
Sense the engine has been swaped and manny cabels cut, i have a small problem knowing what is for what.
Is there more then one ground from the engine to the chassie?
If so; How many and were are they?
model: 1986 Iroc
Mark_ZZ3
May 24, 2018 01:02 PM
BumpaD82
Feb 26, 2016 02:57 PM
2012sergen11
Oct 13, 2015 07:38 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
86White_T/A305
Sep 21, 2015 05:28 PM
