no spark/ power from coil
Old Nov 7, 2005 | 09:09 PM
redcamaro1989's Avatar
Car: 1989 rs RIP, 96 grand marquis, 92rs
Engine: LO3, 4.6l, L03
Transmission: 700r4, AODE,700r4
Axle/Gears: 2.73, 3.08, 2.73
i was driving down the interstate and next thing i know the engine just died instantly. i put on a new distributor cap and rotor and a new ignition coil. im getting no power from the coil wire. what do yall think it is. i have no idea what goes on before the coil. any help would be appreciated
Old Nov 7, 2005 | 09:46 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Ignition Control Module or Pick-Up Coil, both located in the distributor under the cap.
Old Nov 8, 2005 | 12:35 AM
SaintedCorrupt's Avatar
Car: '85 TA
Engine: Carb'd 350, ported 416s
Transmission: retrofitted T5
Axle/Gears: 3.42 7.62" 10-bolt, locker
if Trickster is wrong (which i have never seen before) check for a wire burned on the exhaust or cut by something. basically, follow the wire from the distributor to the battery.
Old Nov 9, 2005 | 06:45 PM
CEP89's Avatar
Car: 89' IROCZ
Engine: 5.7 L98
Getting a wiring diagram would be a good place to start. I assume you mean the 12v power to the primary side of the coil. Check the fuse, if you have power at the fuse but not the coil a cut or burned wire might be the cause. If the fuse is blown it is a short to ground in the wire to the coil.
Azrael91966669
25
Jun 20, 2017 04:04 AM
L98GTA87
Aug 25, 2015 02:23 PM
sailtexas186548
Aug 24, 2015 10:11 PM
transamgta1Khp
Aug 17, 2015 12:18 PM
L98GTA87
Aug 5, 2015 11:02 PM
