Best alternator for the money?...
Old Nov 7, 2005 | 07:52 PM
Trah84Z's Avatar
Car: 1984 Z28 ~Brown Horse~
Engine: 305 V8
Axle/Gears: 3.23...i dunno...
nothing extravagant...just running a daily funner...what would you recommend and why...
Old Nov 7, 2005 | 08:56 PM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: 2.73 Posi w/Disc
If this is for a 'transportation only'-type vehicle with no electrical problems or above-stock electrical demands, I'd go for either a rebuilt alt from Autozone because they're inexpensive and generally last a while or if you wanted to spend more money and basically not have to touch it for the next decade, go for a new GM part. The reasoning behind this is you know all the pieces are matched to each other when it comes direct from GM. A rebuilt may have slightly mis-matched parts, but still work when installed.
Old Nov 7, 2005 | 10:06 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
if you do have a higher electrical load, get a CS144. Either from the wreckers or a parts store. Tell 'em it's the alternator in a '94 Chev lumina van or something.
140 amps, and basically bolts right in.
gta892000
Aug 11, 2019 11:16 AM
92firebirdguy
Sep 1, 2016 07:53 AM
jrdturbo
Mar 31, 2016 02:58 PM
J.C. Denton
Sep 21, 2015 04:23 PM
1Aauto
Sponsored Vendors
Sep 8, 2015 11:14 AM
