ignition on nothing happens
Old Nov 11, 2005 | 04:58 PM
adedirtbiker01's Avatar
Car: 1987 Trans Am
Engine: 305 4BBL
Transmission: AUTO
ok when i turn the ignition switch to the on position no dash lights come on and it wont turn over. the interior lights work and so do the dash backlights. and the marker lights work. i checked the wires from the battery to the starter and from the battery to the alternator.
What can be wrong. somebody help
Old Nov 11, 2005 | 06:58 PM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
did you check the wires from the starter to the fuse block? did you check fuses? reason i ask about the wires is because there are fusible links down there that could be fried. that is basically where the power distribution starts...
Old Nov 12, 2005 | 09:07 AM
Car: 1987 Trans Am
Engine: 305 4BBL
Transmission: AUTO
ok i found a wire coming off the posative terminal that goes into a fusable link and comes out in two wires. i unhooked the connector on the otherside of one of those wires and used the test light and it didnt light up could it be that the link is whats causing nothing to work?
Old Nov 12, 2005 | 01:50 PM
Car: 1987 Trans Am
Engine: 305 4BBL
Transmission: AUTO
never mind i didnt test it correctly. that fuse is good. the wire to the starter is good. the wire to the alternator is good. and the ground to the alternator bracket is good. ?WHAT CAN BE WRONG? would a bad starter make everything go dead. because i cant figure out why the marker lights work but the actual headlights will light up but the motors wont do anything. COULD IT BE IN THE COMPUTER
Old Nov 15, 2005 | 08:19 PM
1fastformula's Avatar
Car: 1989 Formula 350 / 2000 Lightning
Engine: GM HO 350 Crate (Vortec headed w/TPI) / SC 5.4 330
Transmission: Rebuilt 700R4 (Raptor Rebuild Kit)
Check the ground connector going to your frame (from battery to under the car)......It is probably dirty as hell or loose. Undo it and clean it up. Reapply and watch the magic
Later
Old Nov 15, 2005 | 08:42 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
When you say the dash lights, are you by any chance referring to the idiot lights on the dash panel? You know, the ones that say Service engine soon and so forth. Also what ground to the alternator bracket are you talking about?
db057
Jan 10, 2020 08:55 PM
RedLeader289
May 28, 2019 01:47 PM
Gunner242
Dec 25, 2015 04:49 PM
94ElBanditoDeCa
Aftermarket Product Review
Sep 23, 2015 09:05 PM
RedLeader289
Sep 23, 2015 06:50 AM
