Power locks
Old Nov 12, 2005 | 06:29 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Power locks
Does anybody have advice/procedure on installing power lock doors on a non power lock car? Thanks
Brendan
Old Nov 14, 2005 | 08:32 PM
Toehead's Avatar
Never mind, i can figure this out myself. Does anybody know what current the stock door lock switches are rated for? That will determine which resistor i use to limit current, as well as which relay i select.
Old Nov 16, 2005 | 06:37 AM
Toehead's Avatar
bump
Old Nov 18, 2005 | 08:41 AM
Toehead's Avatar
Hello?
Is there anybody in there?
Just nod if you can hear me.
Is there anyone home?
Old Nov 18, 2005 | 12:21 PM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
What resistor? Why are you limiting the current to the door lock solenoids? The swap should be vary straight forward. Are you getting the locks from a donor car or are they after market. Did you score any of the harness at the same time? What about the switches? Adding remote locks at the same time?
But first, have you searched?
Old Nov 18, 2005 | 01:50 PM
Toehead's Avatar
I have searced. I am making my own wiring harness and relay setup. I am limiting the current through the stock lock switches, not the solenoid. I don't want to pick the wrong solenoid and burn out the switches.
Old Nov 19, 2005 | 08:32 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
If you’re using relays the only current through the switches should be the relay coil current, not the lock solenoid current. The door lock solenoid current should all be passing through the relay contacts. If you looking at using Bosh or ‘Bosh style’ relays the current through the switches should be well under 400mA and the contacts are rated for at lest 30A. You can push Bosh relay contacts well past that for short bursts, like locking/unlocking the doors. How are you trying to do this?
Old Nov 19, 2005 | 03:07 PM
Andrew89tpi's Avatar
Car: 91 camaro rs
Engine: 350tpi
This should help you.
http://www.p71interceptor.com/thirdgen/powerlocks
Old Nov 19, 2005 | 04:22 PM
Toehead's Avatar
Awesome. I wasnt sure if the relays had built in current limiting. I know if you use a voltage source without a resistor on some relays, the coil burns out. Nice to know I don't have to worry about it. Thanks for that link!
that will save me trying to figure out what does what with a multimeter
Old Nov 19, 2005 | 09:31 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Buy a reversing relay on Ebay for about 4 bucks, get ten for about $15. Junkyards are full of the GM relays, that's the best bet. Takes some head scratching to figure out the wiring. Door switches will only handle the relay coil current.
Old Nov 20, 2005 | 09:55 AM
Derek The Great's Avatar
Car: 1989 Firebird Formula
Engine: 305 T.B.I. (Vin tag "E" = LO3)
Transmission: THM-700-R4
Axle/Gears: 10 bolt posi 3.23
Originally posted by Toehead
Hello?
ha nice litle ode to pink floyd there
BRoss99
Aug 10, 2025 05:08 PM
IrocBuzz
Camaros Wanted
Nov 20, 2015 11:29 AM
mantaguy
Sep 1, 2015 08:39 PM
sailtexas186548
Aug 24, 2015 10:11 PM
zayne0
Aug 24, 2015 07:22 PM
