cfi to carb swap
Car: 83 chavy z28
cfi to carb swap
ok i have switched out an crossfire injection ona 83 z28 with a 305 to a carb set up. ive already disconnected the brain from the car and was hopeing to take out the wireing harness with it. but there are more wires running up into the dash. can all of these be disconnected? and how do you get the fuel sending unit to still work after you have taken the electric pump out and made it a sump tank with a mechanical pump since the computer controlled it. here is a pic of what i have under the dash.. any ideas???
thanks
steven
thanks
steven
Car: 1989 Iroc-Z
Engine: 5.7L TPI
The fuel sending unit is not associated with the ECM in any way. It sends its signal to the gage in the form of OHM's resistance. The resistance value will vary in regards to the quanity of fuel in the tank. An empty tank will register "0" OHM's and a full tank will register "90" OHM's.
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
Re: cfi to carb swap
any updates?
theshackle
Mar 5, 2017 06:37 PM
