Searching idle.
Old Nov 23, 2005 | 11:57 AM
Bens3rdGen's Avatar
Car: 91 Camaro RS
Engine: Holley MPFI, AFR 195, Hot Cam=375HP
Searching idle.
I was wondering if someone can give me some general causes of a searching idle problem.
It 's fine when I start it and it's cool out, but after I been driving in traffic for a while or it's real hot out, when ever I come to a stop the idle jumps between 800-1800. The funny thing is the speedometer jumps with the rpms. When the rpms jump to 1800 the speedo reads 30mph and when it goes back to idle it goes to 0 mph.
I swapped in a T56 and I'm using a Dakota box to change the VSS signal from digital to analog. The Dakota box is mounted inside the center console near my shifter. It gets very hot in there.
Not sure if this is normal, the whole center console is warm to the touch. Anyway, I think the Dakota box is cooking which is making it give a funny signal to the ecm. The ecm trims fuel based on speedo input right? So if the ecm is getting a roaming signal from the dakota box that would explain my idle problems right?
Thx for your help btw.
Ben
Old Nov 24, 2005 | 02:01 AM
Firebat's Avatar
try to move the dakota digital box to a differnet location or take off your console. Try to make the box cooler just to see if it is causing a problem.
Old Nov 24, 2005 | 02:13 AM
90Formula-X-F's Avatar
Car: 90 Formula
Engine: 355 C.I.
Transmission: 5 Speed
If the car thinks it's moving it could .Why not wire the VSS through the Stock signal signal buffer ? isnt it possible ?
Old Nov 25, 2005 | 01:44 PM
Bens3rdGen's Avatar
Car: 91 Camaro RS
No. The stock signal buffer expects to see an analog signal from a T5 VSS. I have a T56 and it's VSS is digital. They are interchangable. I'll try moving the box. Do you think it's already toast? A new one is $50.
Mark_ZZ3
May 24, 2018 01:02 PM
jaridjohn
Oct 5, 2015 07:01 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
paul_huryk
Oct 1, 2015 04:27 PM
kkirch15
Sep 30, 2015 04:44 PM
