Power to gauges
Old Nov 26, 2005 | 11:53 AM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
Power to gauges
Bought and installed these gauge faces
http://www.procarparts.com/store-det...91CM%2D7073RGX
However I was in a hurry so I kinda jerry rigged it and wired them t othe cigarette lighter (yes I know not a good idea), so now I got them disconnected.
Which wire, which color of wire, is it I would splice into to have them turn on together with the lights/dim switch ?
Basically I need to tap into the gauge light wire, which color is it ? The orange one ?
The gauge faces themselves don't have an on/off switch, just a blue/green light choice switch and intensity adjuster. I could install a switch but not sure about it.
Old Nov 26, 2005 | 02:00 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
No, it would be the gray wire going to pin "6" of connector "C2" on the instrument panel. Also, why would you want to include a switch in the circuit when it is controlled by the light switch anyway?
Old Nov 26, 2005 | 05:02 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
OK gray wire on pin 6 on connector C2.
Do I have to remove the gauges to do this ?
Old Nov 26, 2005 | 07:53 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
No, you should be able to just find the gray wire under the dash and splice it in. Just look for the gray wire that comes off the back of the "INST LMP" fuse on the fuse panel and splice into it.
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Jeremys87
Jul 14, 2022 09:08 PM
Vintageracer
Jan 10, 2020 05:33 PM
sailtexas186548
Aug 24, 2015 10:11 PM
