****in power window motors..
Old Nov 27, 2005 | 05:41 PM
LoudmouthSS's Avatar
Car: 1991 Z28
Engine: SBC
Ok so now that it took me 24 hours to get 1 power window motor done...there is a small, snail looking spring on the bracket that pushes up the windows..is there a clip that holds that on? because if i close my door it falls off?...or maybe im not pushing it far enough on its mounting thing..?
help before i blow my car up
Old Nov 27, 2005 | 09:45 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
You aren't by any chance talking about the heavy spring that goes on this piece are you? If you are, then you might as well go ahead and shoot yourself or blow up the car. It means that you need to get yourself another window regulator. Either you or someone else removed the motor from the regulator and didn't secure the crossmember allowing the spring to fly off.
Old Nov 27, 2005 | 11:18 PM
Car: 1991 Z28
Engine: SBC
this spring
http://memimage.cardomain.net/member...1_122_full.jpg
the window goes up and down fine...but this spring keeps firing off when i close the door...like like its used to prevent the motor from working too hard when it pushes the window back up
Old Nov 27, 2005 | 11:49 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Yep, that is the one that I am referring to.
Old Nov 28, 2005 | 06:30 AM
Car: 1991 Z28
Engine: SBC
but why would i need a new one?....why am i not able to just get this spring back on?
and if i leave it off whats going to happen?
Old Nov 28, 2005 | 07:26 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
That spring is under tension when it is on there and helps to keep pressure on the window to keep it up. Since it has fallen off there is no way you are going to rewind that spring to its original tension. If you leave it off the window will not stay up tight and will be loose.
Old Nov 28, 2005 | 09:09 PM
92F-bird_5spd's Avatar
Car: 1992 Firebird
Engine: 305 TBI
Transmission: T-5 w/ Hurst Shifter
i've been driving around with the spring off for like 2 months now, and my window's been fine. it's goes up and down and works just fine. but seeing as it is a pretty large spring, and it was originally there, i'm assuming what i'm doing is not very smart, and i plan of replacing it as soon as i have time in the near future.
Old Nov 28, 2005 | 09:57 PM
Car: 1991 Z28
Engine: SBC
yea o well..ill just leave it off for now. I think i may take the car to gm and get them to do these motors. Or ill drill through the steel to the rivets on the window motor so i dont have to remove the entire assembly..
Old Nov 29, 2005 | 10:33 PM
Car: 1992 Firebird
Engine: 305 TBI
i managed to remove just the motors because I couldn't get the whole assembly out of the door. I took the whole thing off, and drilled the rivets out while it was still inside the door, just move it to where the big whole is cut and drill it there, then slide the motor out, then you can put the new onw in and rivet or bolt it in and put everything right back. Just make sure you secure the spring somehow on the other side so you don't have the same problem again. I remembered about the spring right after it shot off and almost smashed my window, haha.
Old Jan 7, 2006 | 05:42 PM
92Transam's Avatar
Car: 91 firebird now
Transmission: 5 speed
i have the same prob the previous owner aparently tried to change the motors and did not put a a bolt in the selector gear. so I managed to get the spring back on with a huge vise on my shop table , gloves and vise grips . im not sure if the spring is supossed to shove the part that holds the motor down or up?!! getting back to me asap would be great other wise I have to park my car with the window down at the casino tonight while I work grave yard....
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Sep 13, 2015 09:07 PM
stalkier
Aug 21, 2015 01:54 AM
