Third Brake Light ?
Old Dec 1, 2005 | 05:46 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
Third Brake Light ?
Is there a cheaper fix for these light? All 5 bulbs are burned out and Chevy wants $14.00 a piece for them?
Old Dec 1, 2005 | 06:12 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Do a search on the board, it has been posted several times that radio shack carries a suitable replacement bulb for a couple of bucks each.
Old Dec 1, 2005 | 08:22 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
I did a search. I went 2 radio shacks in order to get all 5 bulbs. I installed them am they work perfectly. all 5 bubs cost less than 1 at Chevy.
In case any else needs it the P/N is 272-1177.
Thanks again.
Old Dec 1, 2005 | 09:22 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
I hope you didn't touch the bulbs with your fingers. The oil from your fingers will cause a hot-spot and the bulb will burn out quickly. You should use a cloth to install the bulb. Clean off the bulbs with alcohol if you made the mistake of touching them to install.
Lon
Old Dec 1, 2005 | 09:47 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
OOPs, Yeah I did touch them. I will wipe them down Tomorrow.
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
stalkier
Aug 21, 2015 01:54 AM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
