cylinder #4 not firing
Old Dec 3, 2005 | 06:16 PM
89mulletbird's Avatar
Car: 89 GTA
Engine: 6.0L Procharged
Axle/Gears: 4.10
I've tracked down my sluggish running problem to cylinder #4 missing.
Using a laser temp gun, all header pipes at the exhaust manifold were 600 degrees F, cylinder 4 was only 300 degrees F. Either it is not getting spark or fuel. It is missing at idle and WOT.
What I've checked so far:
all cylinders compression OK
removed valve cover, all valves moving OK
new ignition mod.
new coil
new plugs
new wires
swapped injector #4 with injector #3, the miss stayed at #4
I still haven't fixed the issue.
Here are my possible questions:
Could the ECM be bad and not sending spark or fuel signal to cylinder #4?
Is there any way to see if injector #4 is getting signal without a oscilloscope?
Any other ideas?
Old Dec 3, 2005 | 07:15 PM
chevymec's Avatar
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
You need to check for spark at that plug and get a noid light and check for injector pulse at the injector.
Old Dec 3, 2005 | 08:51 PM
Car: 89 GTA
Axle/Gears: 4.10
problem found
My new set of plugs had a problem. Plug #4 was cracked and not sparking when under compression.
I guess always check the easy stuff first.
Old Dec 3, 2005 | 11:27 PM
chevymec's Avatar
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
Sounds good enough !!
Old Dec 4, 2005 | 08:32 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Just for future reference thirdgens use batch fire systems so the computer doesn't tell a specific injector to fire, it tells ALL of them to fire.
Old Dec 5, 2005 | 08:25 AM
Vader's Avatar
Except for the later Buicks, which are SFI.
FormulasOnly
Jul 23, 2018 08:47 AM
meeklay812
Oct 1, 2015 03:46 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
indygene
Sep 26, 2015 11:21 AM
