Help Starting Problems
Old Dec 10, 2005 | 07:47 PM
InsaneIROC's Avatar
Car: 89 1LE IROC Z28
Engine: 364 Ci Ls2
Transmission: Mn12 T56
Axle/Gears: Borg Warner 9 Bolt With 3.70 Gears
Ok I have a problem with my 89 starting and running. When I go out to start my car it fires after a couple of cranks but it's missing really bad. It is getting spark and the fule pump is working i have 48 psi at the rails. The motor is new it is not stock it has a comp cam grind XR276HR Big Mouth Base and a Super Ram and about 10.8 compreshion. If I turn it off and try to start it it just cranks but if i let it sit for like 5 hours it will start right up. Last night I was driving it with the bad miss just to put some miles on it and it just died while giving it gas so I pulled over and tryed to start it up and it just cranked. It had spark and the fule pump was working dose anyone know what could be causing this thanks John
Old Dec 10, 2005 | 07:58 PM
GTAfanatic's Avatar
Car: 1988 GTA Black notchback
Engine: 1991 L98 355 TWIN Superchagred
Transmission: 700r4 shift kit 2500 stall
Axle/Gears: www.cardomain.com/id/gtafanatic
has it rained or snowed recently or did you do anything to car before it started doing this?
Old Dec 10, 2005 | 09:25 PM
InsaneIROC's Avatar
Engine: 364 Ci Ls2
No it hasn't rained and it doesn't snow hear do you think that there could be moisture in the cap. the motor is new it has been doning this since i got it running.
Old Dec 11, 2005 | 02:58 AM
GTAfanatic's Avatar
what is your timeing at?
fule press?
Old Dec 11, 2005 | 03:02 AM
GTAfanatic's Avatar
also cheak the plugs
Old Dec 11, 2005 | 01:58 PM
InsaneIROC's Avatar
Engine: 364 Ci Ls2
The timing is set at 6* befor TDC fule pressure is 49 psi
Old Dec 11, 2005 | 11:50 PM
InsaneIROC's Avatar
Engine: 364 Ci Ls2
All of the plugs were fouled with fule so i cleaned them checked the fule pressure it was 49 psi when i statr it pressure drops to 45 psiall plug wires are good MSD 8.5 MM rotor is new but cap has seen better days it runs better now but is still missing anyone have any ideas
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 8, 2015 12:07 PM
