Wiring a switch for cooling fan....
Old Dec 11, 2005 | 05:30 PM
Eighty5's Avatar
Car: 1985 Firebird
Engine: 2.8L
ok,my fan is hard wired,im tired of this as soon as the key turns the fan is on crap,so i figure,i will just run a quick swith right?...
no problem...
then i noticed that this spliced wire that whoever had the vehicle before had added runs from the fan plug into a harness,i have no clue where it is going,i had thought that this wire was just a power and i could dissconnect it from the plug and run it straight into the cab for switch power but i am unsure and would appreciate a little help.
this is where the last owner added his two cents...
and this is the harness it runs into...
does anyone know where this wire is going?,can i just pull the spliced end off it and run it into the cab for switch power,and ground it off anywhere?
i would appreciate any insight that applys to this matter.
Old Dec 11, 2005 | 05:54 PM
JPrevost's Avatar
Car: 91 Red Sled
The best and easiest way (smaller gauge wire) to add a manual fan switch is to use the factory fan relay. I don't have the wiring off the top of my head but if you've got a manual like a Chiltons with the electronic diaghrams you'll find the fan relay.
Old Dec 19, 2005 | 12:18 AM
Dirtbik3r's Avatar
Car: 1992 Camaro RS - not real slow anymore...
Engine: SPDC 360 MAF EFI /w a Holley Stealth Ram
Transmission: T5 untill it blows up from to much torque
Axle/Gears: Ford 9" /w auburn pro & 3.89's
At the fan connector, follow those 2 wires(not the B+ one to battery splice) back to the relay area. See where they go. Does it end up neer the bulk head connector where your fuel and fan relays are?
89GTAOz
May 16, 2020 09:31 AM
Street Lethal
Apr 30, 2019 12:14 PM
Caspar
Jun 19, 2016 11:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
Bryan F
Aug 18, 2015 02:28 PM
