seat belt light
Old Dec 23, 2005 | 07:31 PM
redcamz's Avatar
Car: 84 camaro z28
Engine: 305 H.O.
Transmission: 5 speed
seat belt light
my seatbelt light and chime stop working awhile back, i took the cluster out and change the blub, but it still not working, any help would be appreciated, thank you.
Old Dec 23, 2005 | 10:24 PM
Vader's Avatar
There is an "Audio Alarm" module in the Convenience Center that contains both the chime and a relay to operate the warning lamp.
The larger blue rectangular module is the Audio Alarm. Make sure iot is seated in the socket. You can test the black wire in the socket to make sure it is grounded when the seat belt is disconnected. There is a leaf switch in the belt receiver that should close and ground that circuit when the belt is not connected.
If the alarm works to indicate the key is in the ignition when the door is opened, the audio part is working, and the seat belt portion of the circuit is suspect.
Old Dec 24, 2005 | 01:34 AM
redcamz's Avatar
Car: 84 camaro z28
Engine: 305 H.O.
thanks vader, my chime do work when the key is in the inigtion, so i guess it is the seatbelt part thats having the problem. sorry i am new to this, so where would i start, you think is the seatbelt buckle itself. or should i be looking for something else, thanks.
Old Dec 24, 2005 | 09:12 AM
Vader's Avatar
My first suspicion would be the contact in the belt buckle, or the grounding of the buckle. You can test this by grounding the black wire at the seat belt buckle with the ignition on. The chime should operate in that state, at least for a short time. The lamp should remain on indefinitely, however.
Old Dec 24, 2005 | 12:32 PM
redcamz's Avatar
Car: 84 camaro z28
Engine: 305 H.O.
hey vader, thanks for the picture and the reply. i will give a try at the belt buckle.
Old Dec 24, 2005 | 05:06 PM
redcamz's Avatar
Car: 84 camaro z28
Engine: 305 H.O.
hi vader, i check the seatbelt receive end, is there suppose to be a wire or anything running into the buckle from the carpet? just wondering how they get the signal that it is not buckle. by the way, if my door is open and the key is in, the chime will sound, just no chime or warning light for the seatbelt. thanks again
Old Dec 25, 2005 | 10:19 AM
89RJcamaroRS's Avatar
Car: 1989 camaro RS
Engine: RAMJET 350
Transmission: RAPTOR 700-R4
i do believe the grounding wire is on the retractor not the receiver
Old Dec 25, 2005 | 11:46 AM
Vader's Avatar
Merry Christmas to all. For those who don't celebrate, have a nice day.
I do believe RamJet is correct. The older systems have a cam-actuated switch in the retractor. The newer systems have contacts in the receiver end buckle, and require that something is actually plugged in there to open the contacts.
If you observe the clear plastic cover on the end of the retractor bobbin, you should see the contacts. By simply groundnig the wire to the retractor, the lamp should turn on. This should help determine whether the problem is in the retractor or the wiring/module part of the circuit. If grounding the wire doesn't turn on the lamp, don't bother opening the retractor. If it does operate teh lamp, you need to repair the switch. The cover can be removed carefully and glued back in position. It's been a while since I've played with this type, by I know it can be done.
1992 Trans Am
May 10, 2023 07:19 PM
MORREALE5
Sep 13, 2015 09:16 PM
TRANSAM82-92
Interior Parts Wanted
Aug 15, 2015 01:26 PM
Omega
Aug 10, 2015 12:46 PM
scottmoyer
Aug 9, 2015 10:18 PM
