temp guage problem
Old Dec 28, 2005 | 04:45 PM
87and 93birds's Avatar
Car: 87bird and 93 formula
Engine: 305 and 350
Transmission: auto
temp guage problem
guage pins out over 260 when car warms up and then jumps down to 200. i replaced the thermostat and antifreeze and still the same problem. dont want to keep dumping in money if it is not the problem. has anybody had the same problem if so what did you do to fix it? also it is on my 87
Old Dec 28, 2005 | 05:21 PM
cc 82Z-28's Avatar
Car: 82 Z-28
Engine: Built 406ci
Transmission: 700R4 w/3000 stall
Axle/Gears: 3.73 Torsen Posi, Moser Axles
Mine is doing the same thing but I believe that you, like me, are going to need to change out the sending unit screwed in the passeger side head. Mine is original to the car which is 1982!! Guess it's time for a change.
Old Dec 28, 2005 | 06:11 PM
Engine: 305 and 350
Transmission: auto
hopefully thats all. i was just going to change the one in the thermostat housing next but ill try the other then. thanks
Old Dec 28, 2005 | 06:14 PM
cc 82Z-28's Avatar
Car: 82 Z-28
Engine: Built 406ci
That one is for the computer info to the ECM. The one in the head is for the gauge itself.
Old Dec 28, 2005 | 06:16 PM
Engine: 305 and 350
Transmission: auto
i thought the one on the head was for the ecm because that was the one i replaced for the fan switch which runs by the ecm.
Old Dec 28, 2005 | 06:28 PM
cc 82Z-28's Avatar
Car: 82 Z-28
Engine: Built 406ci
I'm not sure about that since my car has a mechanical fan and no ECM, but I do know that the one on the head if disconnected kills my temp gauge, no reading. Now maybe on yours the wiring ties into something else such as your fan, that I'm not sure of. I would think the one on the thermostat housing could be part of the ECM for the fan and such but maybe not. Is there another one in the other head?
Old Dec 29, 2005 | 05:49 PM
Dizturbed One's Avatar
Car: 92 RS
Engine: a slow one
Transmission: a crunchy one
Axle/Gears: a whiny one
the one in the intake manifold is your Coolant Temp Sensor for the ECM
the one in the head is your Sending Unit for the gauge
mines all jacked up too... i replaced the CTS, and decided if that didn't fix it, then I don't care, because at least the COMPUTER knows how hot it is and when to turn the fan on.
and it does, although my temp gauge will be all over sometimes, the fan always seems to turn on at the same temp under the same conditions.
Ghettobird52
Jul 5, 2024 11:18 PM
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
greenyone
Sep 2, 2015 03:39 PM
355sbcTPI
Aug 19, 2015 04:38 PM
