HEI Diagnostics...help!
Old Jan 1, 2006 | 12:47 PM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
Just dropped in a fresh motor in my IROC and she won't fire. I've got 12 volts to the HEI but no spark. Must be the HEI but where do I start to look for the problem. It's an MSD Super HEI with about 25 miles on it. Worked fine until the new motor was installed. Confused.
Old Jan 1, 2006 | 10:05 PM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
check the control module. Make sure the voltage wire is plugged into the correct spot.
Old Jan 2, 2006 | 05:46 PM
wesilva's Avatar
Transmission: 200R4
Perfect call on the module, LT1. I put in a spare module from Performance Distributers and it fired right up. Who would have guessed that the problem would happen after only 25 miles from such a reputable company as MSD? Hopefully I can get a refund. I don't recall what the duration of the warranty was.
Old Jan 2, 2006 | 05:55 PM
1981LT1's Avatar
Engine: LT1; LT1
the gm style module is a funny thing. They give no warning of what is about to happen and then leave you stranded.
sreZ28
Oct 22, 2015 08:21 AM
skinny z
Oct 5, 2015 06:23 PM
Justins86bird
Sep 27, 2015 09:43 AM
Damon
Sep 26, 2015 04:29 PM
RedLeader289
Sep 23, 2015 06:50 AM
