so i finally got around to fixing the regulator in the car
Old Jan 8, 2006 | 05:31 PM
LoudmouthSS's Avatar
Car: 1991 Z28
Engine: SBC
So i put the new regulator into the car and mounted it all up...was looking great. Then i hit the "down button", and it started to go down...got about an inch and 1/2 down and stopped. It doesnt look like anything is stopping it from going down either. The windo is nice a flush when its all the way up too. Anybody have any suggestions?
Old Jan 16, 2006 | 11:20 PM
Car: 1991 Z28
Engine: SBC
anybody?
i have a feeling when i remounted the spring on the regulator i may have mounted it the wrong way..anybody have a pic of the spring on the regulator?
Old Jan 21, 2006 | 11:25 AM
Vader's Avatar
Will this get you close?
Attached Thumbnails so i finally got around to fixing the regulator in the car-powerregulators.jpg
Old Jan 21, 2006 | 03:42 PM
Car: 1991 Z28
Engine: SBC
yes thank you lol ok so i got the spring mounted the right way...
the what the hell could be stopping it
Old Jan 21, 2006 | 04:27 PM
Andrew89tpi's Avatar
Car: 91 camaro rs
Engine: 350tpi
This is probably what you don't want to hear. http://www.p71interceptor.com/thirdgen/powerwindows
Power Window Retrofit
"Do not confuse the drivers side and passengers side regulators, they look very similar but each is unique. During the swap, I somehow managed to confuse the two and had symptoms of the window only having a travel range from the fully rolled up position to a few inches below the fully rolled up position. Window would not even come close to being fully open."
Old Jan 21, 2006 | 05:00 PM
Car: 1991 Z28
Engine: SBC
hmm oops..must have mounted the spring wrong then lol, no biggy, i looked at the passanger side and the spring is mounted differently..the drivers is upside down, the passangers is right side up.
Old Jan 21, 2006 | 05:22 PM
Car: 91 camaro rs
Engine: 350tpi
Is that your original regulator or did you get a replacement? I ask because they may have given you the wrong side.
Old Jan 21, 2006 | 11:40 PM
Car: 1991 Z28
Engine: SBC
yea its the original driver side one..just mounted the spring wrong when i was putting it back under tension...oops
MustangBeater20
Oct 29, 2022 09:20 PM
9192camaro
16
Feb 3, 2019 12:21 AM
beachrodder
Aug 25, 2015 08:05 AM
Kaweh
Aug 9, 2015 02:54 PM
Amillionoh7
Aug 7, 2015 01:24 PM
