Can a '91 GTA column w/ key work fine in my '91T/A?
Old Jan 12, 2006 | 08:28 PM
BigWhiteGTP's Avatar
Car: 1994 Trans Am
I want to replace my crappy '91 column with one from a '91 (same year ) GTA. I will have the key as well. Now will it be a simple plug-n-play thing, where everything snaps together and everything is fine and works like it did from day 1 OR will there always be a VATs problem between 2 different columns, regardless of years?
Thanks guys!!
Old Jan 12, 2006 | 09:13 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
you will need a key cut for the new column that has the VATS resistor for the old column, unless you got lucky & both keys have the same resistance on the VATS pellet, its a 1 in 15 chance.
Old Jan 12, 2006 | 09:17 PM
Car: 1994 Trans Am
Anyway to tell? Like a code number on part of the columns?
Old Jan 13, 2006 | 01:43 AM
DENN_SHAH's Avatar
you can measure the resistance of the pellets of both keys.
1992Z28!
Nov 19, 2015 07:33 AM
Eric-86sc
Sep 28, 2015 11:37 AM
Dragonsys
Sep 25, 2015 03:51 PM
383cam
Sep 9, 2015 06:01 AM
