how to wire up rear defrost
Old Jan 15, 2006 | 05:47 PM
dwillis's Avatar
Car: 1991 Trans Am Convertible
Axle/Gears: 3:08
how does the rear defrost wire up to the fuse panel on a 92 that doesn'have rear defrost...( i,ve got a lid with defrost now)
Old Jan 19, 2006 | 11:31 PM
kurfbird's Avatar
Car: 1992 Firebird v6 1992 formula v8
Engine: 3.1, 350 TPI
Transmission: both 700 r4
Wiring a 92 Firebird with defrost
1st
Great thing abvout third gens is that the plugs you need will already be there you just need to add the components.
Go to a junk yard. ANd find a 3rg gen with rear defrost. Get the wirng that runs to the frame.
Also get the purple wiring that comes form the front of the car. It is on the drivers side under the door plastic peices. Big purple wire. It has a plug by the fuse panel. Make sure that you disconect the plug.
Also get defrost relay. On pass side under small plastic peice right under the bird pocket. Not sure where it is on a camaro
You will also need a defrost switch. AT least on the firebirds. That is what I added a defrost hatch on.
When you get the parts just put them on in reverse.
1992 Trans Am
May 10, 2023 07:19 PM
Jorlain
Aug 24, 2022 05:11 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
AkDrifted
Aug 17, 2015 07:45 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
