fuel pump wiring tpi to carb
Old Jan 17, 2006 | 08:04 PM
rjt76's Avatar
Car: 1986 iroc z
Engine: vortec 383
Transmission: th350
Axle/Gears: 3.73 moser 12 bolt true trac
can someone please tell me where to tap into the wiring for the fuel pump? I figured you tpi guys would no best. I have removed and sold everything tpi related under the hood (unpluged not cut). so where do i find the fuel pump wiring to setup a switch of some sort? the relays went with the tpi. I will be running the mallory regulator and need this info and yes i have been searching...thank you very much guys....ryan
Old Jan 18, 2006 | 12:23 PM
Vader's Avatar
You can install another relay in place of the one that went away with the TPI parts and harness, or use the oil pressure switch to power the pump. Using the oil pressure switch will be no different than a mechanical fuel pump with a carbed engine, since no fuel is delivered until the engine is cranked in either case. You'll want to fuse the supply to the oil pressure switch just like the factory TPI harness provided,
Old Jan 18, 2006 | 11:15 PM
rjt76's Avatar
Car: 1986 iroc z
Engine: vortec 383
Transmission: th350
I removed and sold the tpi harness so there is no wiring left. where do i dig for it to tap into the pump wires?
Old Jan 19, 2006 | 12:15 AM
Vader's Avatar
There should be a tan wire from the tank/pump connector, through the interior under the rear seat, along the floor/threshold to the firewall, and through the firewall to the engine compartment.
Old Jan 19, 2006 | 07:11 AM
rjt76's Avatar
Car: 1986 iroc z
Engine: vortec 383
Transmission: th350
vader, could this be one of my pump wires? I know its not tan but thats all i got coming through the firewall....thanks
http://pg.photos.yahoo.com/ph/rtninj...nm=5303re2.jpg
Old Jan 19, 2006 | 12:53 PM
Vader's Avatar
I'm not sure of the color rendition of my graphics viewer. Are those orange and green wires, or a red and green wires? Or blue? And tracers (stripes)?
I'm about certain those aren't the fuel pump circuit, either way.
Old Jan 19, 2006 | 04:42 PM
rjt76's Avatar
Car: 1986 iroc z
Engine: vortec 383
Transmission: th350
brownish color and the other is greenish color.
RazorN8
Jan 7, 2022 11:44 AM
Grant2k
Jul 10, 2018 04:01 PM
theshackle
Mar 5, 2017 06:37 PM
Jae992
Aug 27, 2015 09:07 AM
beachrodder
Aug 25, 2015 08:05 AM
