Do my TA have an electronic Speedo?
Old Jan 17, 2006 | 11:24 AM
Nonni's Avatar
Car: 86 T/A
Engine: ZZ383
Transmission: TH700R4 Raptor
Axle/Gears: 2,7x -> 3.00 or 3.50
I have a 1986 Transam, was with LG4 and carb, and TH700R4. Now I am going to buy kit from B&M for the lockup, but I am not sure if I should buy for mechanic or electronic.
Is anybody out there that can clear it out for me.
thanks, Jon H.
Old Jan 18, 2006 | 08:52 AM
Vader's Avatar
AFAIK, all '86 Firebirds had the VSS mounted on the transmission, and no speedometer cable. Mine does. since your's may be an export model, it may be different, however. If there is no bowden cable from the transmission to the instrument cluster, you have an electric speedometer.
Old Jan 19, 2006 | 05:02 PM
supercrossman's Avatar
Car: 86' TA
One easy way to tell is go in a empty parking lot and shut your car off while your rolling if the speedo dies its electric if it goes untill you stop its mechanical. Allot easier then checking for the cable or anything else
InfernalVortex
Apr 20, 2021 11:31 AM
Elephantismo
Feb 13, 2019 12:51 AM
MrPackstin
Oct 25, 2017 08:09 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
anesthes
Sep 30, 2015 07:48 AM
