Headlight Problem
Car: 1986 Pontiac Firebird
Engine: Modified Chevy 350
Transmission: 700-R4
Axle/Gears: GM 10 bolt 3.73 gears
Headlight Problem
When I flip the headlight switch on my 86' Firebird to the on position the head lights turn on a come up but when i flip it off the interior lights go out but the headlights stay up and the lights stay on. Then after that I would take the headlight fuse out of the fuse box and they would turn off but not go down. Then with the headlight switch off and i put the fuse back in the lights go down. Can anyone help me with this problem?
Jay
Jay
About the only possibility I can conceive given your description of the symptoms is that the switch itself is failing. A failing isolation relay might keep teh headlight doors elevated, but would not keep the lamps lit.
Ghettobird52
Jul 5, 2024 11:18 PM
