Gauge lights stopped working
Old Jan 25, 2006 | 07:17 PM
kubus_stroinski's Avatar
Car: 1991 Camaro RS
Axle/Gears: Tru-Track posi/Moser axles/4.10
Hey,
I have a 1991 Camaro RS with the auto light sensing thing. My lights turn on automatically when it gets dark. A couple of months ago, my gauge lights just turned off while all of the other lights in the car stayed on (HVAC stuff and gear selector light). I could make them work by lightly hitting the side of the gauge cluster. This worked up until last weekend. Now driving at night is very difficult because i have no idea how fast im going and am afraid i might get pulled over by a cop. Im assuming that its just a poor electrical connection to the lights for the gauges. Can anyone tell me how i should fix this problem? what wire it could be? where the connection may have failed? thanks a lot!!!
Kubus
Old Jan 25, 2006 | 09:13 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Just a thought, it could be the dimmer control in your light switch.
Old Jan 25, 2006 | 09:16 PM
Car: 1991 Camaro RS
i dont think it would be though just because all of the other interior lights are working. the only ones that dont work are the actual gauges
Old Jan 25, 2006 | 09:29 PM
Al Hasse's Avatar
You're right, I read over the part that says the HVAC lights stay on.
Old Jan 27, 2006 | 10:21 AM
Vader's Avatar
You have a few options:
  1. Hit the cluster harded. You'll either get lucky, or you'll completely break it, and have to remove it (whereupon you can repair the original problem while replacing the cluster);
  2. Clench a small flashlight in your teeth while driving. At least they won't give you a ticket for talking on your celly along with the speeding citation;
  3. Drive like a Florida voter so you never get a speeding ticket;
  4. Don't drive at night (also see #3);
  5. Remove the instrument cluster, repair the lamps, and repair the I/P connectors as necessary.
It's fairly easy to remove the panel, and the foil connections at the edges are easy to inspect once its removed:
Old Jan 27, 2006 | 10:13 PM
Car: 1991 Camaro RS
i took the cluster out and cleaned all connectors and also changed all bulbs while i was at it. works like a charm now. its even brighter than it was before. the only problem i had was my battery died while doing this so i had to recharge it. taking out that dimmer **** is a royal pain as well. thanks for all your help
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
Reddeath210
Oct 6, 2015 08:20 AM
Wade787b
Sep 29, 2015 01:15 PM
justin57
Aug 20, 2015 07:05 PM
Omega
Aug 10, 2015 12:46 PM
